Dec 16, 2016
52
Sussex
Evening all,
I have built a 2 DOF VR Roller Coaster simulator.
I am now adding additional realism, specifically wind.
This is the specification of the inline air pump that I am going to use,
Inline Blower | 270 CFM 4″ In-Line Bilge Blower Fan - http://www.seaflo.com/en-us/product/detail/663.html
Model
SFIB1-270-02
Voltage
12V DC
Air Flow (cfm/cmh)
270/456
Max Draw (A)
6.0A
Fuse (A)
10.0A
I need to source a 240v (i.e plug in uk socket) device that will power this, I do not need a battery that stores, but one that runs off mains and isn't to bulky.
I have no real idea where to start, I am also concerned with how to wire it up as I will need a quick release system as the unit is transported all the time from event to event.
I may add further blowers moving forward so something that can handle more than 1 would be great! Or multiple outputs for different things moving forward.
Thanks for any help!
Interesting project how are you going to control the fan speed to replicate the roller coaster variable speed for wind also may I ask if this is a dead end project as you do not need the environmental factors for your brain to feel the immersion.
Now this post is off the beaton tracks .:D
Reactions: Darkwood
I am going to use a MonsterMoto and ArduinoUno, the output from the simulation software I use and a little bit of code. This side is documented at another forum I use.
Its the first time I have DIY powered, anything, so thought I call in the big guns to assist me!
Sussex
Help needed re simulator parts power requirements
Gaming Forum
Shoshin,
Shoshin,
