Hey all,
Could I get help with wiring this double switch which will be individually switching front and back external lights.
With this switch I have a live source from consumer unit going in, and 2 separate cables going in for front and back lights.
so when I connect live in from consumer unit I would connect to live 1 in on left and then place a live loop from live in 1 left to live in 1 right To power both switches ?
with the neutral cable coming in from consumer unit would I put this in left 3 and then loop across to right 3?
with separate out going cables connect live to live 2 out with one cable and connect other cable for other light and switch to live out 2 on right ?
then neutral from cable out on left to out 3 and neutral cable from right out to out 3 on right ?
if that makes sense ?
So basically I would like a switch to front light and a separate switch to back light
cheers Rich
cheers Rich
