Discuss Help wiring tankless water heater. in the DIY Electrical Advice area at ElectriciansForums.net
Rozmere
Okay, so a while back my old water heater tank for my mobile home finally gave up. It isn't as easy as replacing an element this time, it's totally dead. So I need to install a new tankless water heater and I'm planning on getting the "Ecosmart Eco 18". The plumbing part is a no-brainer, I've done tons of plumbing but I've only done a little electrical work and it's been years ago so I need advice. BTW I have very little money so that's why I'm having to do this myself.
The specs for this water heater say kw: 18; volts: 240; breaker: (2) 40 A; required wire: (2) 8 AWG
So I want to make sure I get the correct wire and breakers. So are these items what I need? Do you have different suggestions? (BTW the water heater will be less than 25' from the breaker box that is in another room)
(2) Wire: https://www.amazon.com/InstallGear-...lja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ&th=1
(2) Breakers: SIEMENS Q240 40-Amp Double Pole Type QP Circuit Breaker black - - Amazon.com - https://www.amazon.com/Q240-40-Amp-Double-Circuit-Breaker/dp/B00002N5HK/ref=sr_1_5?dchild=1&keywords=40a+breaker&qid=1622406422&sr=8-5
(1) Ground Wire: Copper Ground Wire MTW 8 Gauge AWG Green/Yellow Stripe 19 Strands 25' FT: Amazon.com: Industrial & Scientific - https://www.amazon.com/gp/product/B07PRXCTBP/ref=ewc_pr_img_1?smid=AF5R0QSE27JYB&psc=1
Reply to Help wiring tankless water heater. in the DIY Electrical Advice area at ElectriciansForums.net
I'm installing a Rheem Retex-27 27kw electric water heater. While it's not required by the code where I am, I'd like to have a disconnect switch...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
I have a regular sized tub. I would like to be able to heat the water to a certain temperature. I've been looking at on-demand heaters for this...
Hello, Question is regarding a recently purchased property in Central Texas, which includes a 27KW tankless electric water heater. It is four...
