I've just repaced my hotwater and central heating progrmmer with a Hive active heatng and hot water thermostat. It's all working but the thermostat is still connected, I've turned it up to full so it's always calling for heat but I want to put the Hive thermostat in its place so need to disconnect it..
From the wiring box it looks like I just need to disconnect the thermostat and then connect the red wire from block 3 into block 4 is that right?
