dommi32
Hi fellas
Im just starting out on my own and ive been asked to quote first commercial job. Ive worked on all sorts from domestic to industrial but this is the first non domestic job that ive had to quote.
Basically need to supply a 16mm swa to 10 way 17th cu. then supplying 10 twin skts all in 20mm plastic. move a load of recess lighting in a suspended ceiling and wire 2 bulkheads with 8 spots on each, an illumanated menu and 2 outside signs. 3 aircon units in suspended ceiling need wiring. and main gas bonding. all additional lighting going to an 8 gang grid switch. the swa run is 28 mtrs.also have 6 cctv cameras to wire in plastic tube. its basically a bank transformed into a fast food restaurant. emergency lighting and fire alarms are already in.
Ive quoted 8.5 days on my own plus materials.do you think £2300 is reallistic.
cheers guys
cheers guys
