E
ezzzekiel
when end to end ring testing if one conductor is higher (but not broken) than expected what method do you use to locate the loose connection the quickest
2 plug in thingys is bestIf you've got a plug in thingy then i like pushrod's idea, not tried that before. That way you could narrow down possibly without any dismantlisationing.
, especially if you have an awkwardly sited CU.
