Discuss Home Made RCD tester anyone? in the UK Electrical Forum area at ElectriciansForums.net
This is wrong on so many levels.Totally ignoring the actual plug top abomination,the earths on the socket have been linked between each other? Why for gods sake?.The earth from the rcd looks like it has been taken off the neutral side of the rcd?:eek:
So now i can throw away my £600 MFT as I dont need it any more with his home made tester? Who knew?;)
Reply to Home Made RCD tester anyone? in the UK Electrical Forum area at ElectriciansForums.net
Hi to Everyone. Anyone has done a personal interface to communicate DLRO100H using SCPI commands? i´m using Visual studio2022 sotfware, and i´m...
What should you do if a client has a CU that is a split board protected by 2 * 63Amp 30mA double pole RCCDs, you took Zs and tested both RCCDs by...
Today I was doing an EICR and went around a couple sockets with a Megger MST220 socket tester just to see if there was anything obvious, all three...
Called out to fault on RCD tripping maybe twice in a month for sometime. Did all the tests & found RCD was faulty, Refitted a new Rcd Type A which...
I have a PeakTech Digital resistance tester for sale, still in it original packaging, never used, cardboard box is a bit shop soiled, but the...
