G
Gaz123
Hi all,
I am having a bit of a headache trying to get my Accenta Gen4 mini to talk to my newly installed Honeywell Informa.
The panel has been fitted for a couple of years and works fine. I connected the Informa up as per the instructions, using the following wiring
Panel Informa
INT = IP1
PA = IP2
FIRE = IP3
SET = INH
Informa is powered from the panels comms 12v and 0v supply.
The informa itself seems to work fine, in that it will record and dial out using its test features. But, it does not activate when the alarm is triggered.
Tried changing the input levels from low to high, but no joy. Manual states low should be used to set back to that.
Am I doing something obviously wrong...it's driving me mad :banghead:
Any advice appreciated.
Cheers
Gareth
Had a bit of success. If I enter engineer mode on the informa, choose 0 to show input status. Then testing the outputs from the panel shows the relevant led on the informa. So they are talking to each other...it just doesn't seem to dial on alarm trigger. Must be something with his I've programmed it.
I might try resetting the nvram and starting from scratch.
The informa will not dial out unless the system is set, to test or remove this feature so PA & Fire work ....remove the wire from INH & set. The unit will then always dial out when triggered.
Thanks Tazz. Found that useful. Managed to get it working after nvram reset. Think I had changed sequential dialling off, so informa wanting specific number for different events, rather than just dialling in order.
Inh to set is still connected at no, so will disconnect that.
Cheers
Honeywell Accenta Gen4 & Informa help
Gaz123,
Gaz123,
