Discuss Honeywell key fob programming in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Tilara
Hello, I am having difficulty programming my Honeywell 5834-4 key fob. I am using a Honeywell 21ip with a 6160RF receiver. I am able to program the stay button on loop 4 using both *56 and *58 programming modes but when I try to program alarm away I get an error tone when I press * to accept loop 3 and it will not allow me to go any further. My only option is to back out using the pound key.
I have not had trouble programming all of my wireless door/window contacts or motion detectors, fire detectors etc. I installed a Tuxedo WIFI that is operating perfectly. This 21ip panel and 6160RF receiver were purchased used in perfect condition. I did a factory reset before I started programming.
I've been stuck on this key fob problem for over a month. I sure would appreciate any help someone can offer.
Reply to Honeywell key fob programming in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hello Please help me to understand more about the kinetic switch! i have 6 quinetic wifi wireless receiver for dimmer switch (1AMP)and 3- 2 gang...
8K
HI, My project involves installing under-cabinet lights. Wiring is there and waiting. Have any of you seen differences, gains, sacrifices by...
Hello to everybody taking the time to read this post. I hope it is oK to post this here. I will start by introducing myself, I'm Martin from...
Hello All, I am hoping to find a recommendation from members for a small tube of adhesive that is suitable for gluing Burglar Alarm detector...
14K
Honeywell ADE Accenta G4 panel & 8EP417A RKP Wondered if anyone can help please. Just installed the above & initially had a problem with tamper...
6K
