Discuss Honeywell Wiring Guide in the Central Heating Systems area at ElectriciansForums.net
O
Octopus
A plumber mate of mine passed me this a couple of days ago...
Loads of useful stuff in here and not just about Honeywell kit!
All you have to do is call them and ask for a copy
Now, I am sure that is your left foot in shot with the grey sock on.
The other I assume is your right leg. If it is not your leg, then fairplay to you mate!!
Reply to Honeywell Wiring Guide in the Central Heating Systems area at ElectriciansForums.net
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
Hello everyone. I have an older M1M on the board in the furnace it only has four connectors and connections: C (Blue wire) W (White wire) G...
Hello I need to put back a Honeywell Thermostat. There is 3 wires and a earth I have placed the current thermostat wiring in image one and in...
4K
Hi I need some help on how to wire up this nightmare... (They're usual sparky had an argument with customer and left job)...Trying to help a mate...
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
