Check the installation instructions. Fusing would be at a FCU supplying the fan. The problem I have alluded to is regards an electrician who fitted a fan but did not do as the instructions advised. The fan caught fire and the electrician went to the gallows (figuratively speaking) If you are fitting a new fan you must comply with current requirements. They do seem to say that if the connection is more than 2.5 metres long... And in fact they recommend a 5a fuse so that clears that one up.
all the cables are there, so the most likely variable is that you have connected them wrong
Hi - fusing with the small fuse as per @Vortigern post 16 is manufacturer's recommendation for protection against fire. It won't make the fan work if it's wired incorrectly, or busted. Reality is you probably need test equipment to see what's happening. Please be careful with those wires !
Xpelair will say in their literature, An Electrician must fit this. You might invalidate your house insurance if the fan catches fire. Is it fused to 3a? Again probably recommended by manufacturer. I think you should call an electrician.
Do you mean on the fuse box? I simply took the old one out. Then took the 3 cable of Live, SL and Neutral and wired as instructions say, tested new unit before fitting and this is what happened.
I have read that this has been a problem on another thread?
I have tested it with my multi meter. Switched live is switching but still not working. I have just cut and re- stripped them :)
From the pic of the new fan the red and yellow need swapping to correspond with the old fan connections and theoretically it should function. Had the old fan stopped operating.
Thanks, that is how I have it and it is constantly on once the isolator is turned on. The light switch does nothing. Then the only way to turn off is switch off isolation switch.
Do pros install these extra fuse on the wiring diagram above. It says 5 but the main unit is a 6amp fuse. Is there any simple way to do thus please?
After testing the cables in they all work. The old unit plugged back in works as it should.
I am thinking either the transformer unit is duff or I just wire it so the timer doesn’t work.
But this 5 amp fuse thing.
All my lights are now LED bulbs in the entire house, so the current they draw on the circuit is miles less. Can I just swap the main fuse to a 5 amp? Would that be the same as a 5 amp in line fuse?
Thanks for peoples’ help.
The manufacturer recommends the fuse for fire protection in the event the fan should seize the fuse should blow, this is normally 3A but the absence of the fuse will not prevent correct operation of the fan.
It is not the main "fuse" I am talking about that is 6a, leave that alone. So on your boiler for instance is there a switch that the wire for the boiler comes out? If so that is a fused spur, it has a fuse in it local to the appliance separate from the MCB at your consumer unit. I am saying the supply to the fan should be on a triple pole isolator usually outside the bathroom with a switched and fused spur giving the supply. Is it difficult? well it's easy if you know how. Don't take a chance get an electricican to make sure everything is as it should be.
THanks i understand what needs doing but that means another crazy expense for what seems to be a nonsense.
I have been looking at the click mini grid. But it will create a massive eyesore.
I think I will look for another fan that does not need this fuse. Another thread mentions some manufacturers.
If it's not working you have a problem with the fan or the the switched live cable
The switched live cable tells the fan when the light comes on and to activate the permanent live is to keep it running the additional time set by the timer
Get a spark to test and fit
Thanks for all your help. Last question I promise.
I am very interested in your comment about switched live. I did some more tests. With the switched live off (switch contacts open) there is still 70 volts showing between SL and neutral. Then normal 240 with switch contacts closed.
Would you expect that? Seems a bit odd to me to get 70 volts, hence why I ponder your switched live potential issue you raised?
The spark is going to come if I can get him.
