T
The Ghost
Check the installation instructions. Fusing would be at a FCU supplying the fan. The problem I have alluded to is regards an electrician who fitted a fan but did not do as the instructions advised. The fan caught fire and the electrician went to the gallows (figuratively speaking) If you are fitting a new fan you must comply with current requirements. They do seem to say that if the connection is more than 2.5 metres long... And in fact they recommend a 5a fuse so that clears that one up.
