- Apr 4, 2022
- 69
- 35
- 93
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- All Other Countries (This Is English Speaking Website Only - WE don't mind Google Translate Users :)
- What type of forum member are you?
- DIY or Homeowner (Perhaps seeking pro advice, or an electrician)
Cheers everyone.
I'm here trying to install a pair of outdoor R7s floodlights and reading the manual (who does that? I do.) it mentions multiple times the horizontal tilt of the fixture should be "Ideally 0º or <5º" because otherwise the lamp will "burn too fast" with no more clarifications
Lights are 78mm 250W.
My questions are
a) is the manual right?
b) why would the lamp burn if tilted exactly at a >5º angle?
I'm thinking uneven heat dissipation with one of the sides getting hotter and damaging the filament inside, but isn't the lamp designed for that? getting hot that is, that's how it emits light after all.
Planning to leave them on for at least 8 hours, is that OK? no PIR, I've seen this kind of lights paired with PIRs before
I live in a rural area and basically we've been having trouble with wild cats attacking our roosters, and it's said they won't sneak in that much if there are lights on outside, otherwise when we go to sleep and the indoors lights are off it's a pitch dark place, perfect for these night predators. I like cats too but not when they're trying to kill our animals
My questions are
