Discuss hot gas cut off solenoid valve in the Australia area at ElectriciansForums.net
Hi client called me and they got a hot solenoid .....its almost getting too hot to touch....? Its for the emergency gas cut so kinda need to be sorted....thinking lose termination but any thoughts i could get before i go into it?
I've come accross hot solenoids myself too, quite a few infact. Seems that's the way they are......
especially in safety critical situations like gas, they SLAM open or shut but during normal operation all that power has little to do but dissipate as heat.
Reply to hot gas cut off solenoid valve in the Australia area at ElectriciansForums.net
Hi all looking for some helpful advice I'm an Aussie so go easy on me, I have a good mechanical engineering head but first time plumbing and...
Hi, We are designing and building cooking gas bottles with electronics controlled valves. These are for kids camping chalets. Its purely a...
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
Bit of a strange one ive been told by everyone ive called had a triton t70xr 8.5kw The water started running cold like the tco kicked in after a...
