Discuss Hot spot thermometer.... Homebase in the Electrical Tools and Products area at ElectriciansForums.net
There are cheaper ones available;
https://www.NoLinkingToThis/p/stanley-stht0-77365-infrared-non-contact-digital-thermometer/8374j
I've had one, not the above, for over 20 years mainly for measuring air temperatures but have used it on cable connections in Commercial buildings and found hot spots.
I used something like this eears ago to check for loose connections on a some pretty heavy sub mains on a big site. There had been a fire in one of them, so everything got checked when it was loaded up.
I don't know if it'll just sit in my van and never get used.
I have one of these https://uk.farnell.com/fluke/fluke-ti9/thermal-imager-160-x-120-15cm/dp/1700079
great piece of kit for checking control panels and DBs. Also really handy for finding joist under plasterboard. Worked a treat on my bay window for putting the curtains up !
i have an ethos one. had it 5 years. cost about £20. works perfectly. main use is electrical ( hot cables/switches etc. and checking the freezers are @ -20.
Has anyone any experience with these?
Keep being tempted, not exactly something that will break the bank but could end up paying for itself in a few hours on a breakdown.
I just brought the flir C3 I'll let you know how i get on with it tommorow
Occasionally you find a warm object (36C) that keeps moving - Reflection of your bare arm , on some shiny surface -at just the right angle .
(Those ghost hunters have a lot to answer for)
Reply to Hot spot thermometer.... Homebase in the Electrical Tools and Products area at ElectriciansForums.net
Good evening all. I have a couple of learners with hypermobility issues - which causes their hands to be sore after a day in the workshop. Has...
Hi Forum, I had drain cameras plumbing equipment and tools, I was just wondering how much voltage the right drain cameras would have if we...
As I have retired now (really!) I have decided to sell my electrical tools etc. They include hand tools, hilmor galv. conduit bender 20/32 with...
Hello, Looking for DIY electrical advice. I have 7 x spots, and each are fitted with 1 x T&E connector block fitting [see photo]. In the past...
Homebase are having a sell off of their USB rechargeable led task / under cupboard lights. They come with a magnetic holder seen in Homebase...
