M
matt12345
A customer of mine has recently had a 20a hot tub installed by a third party company. They have fitted a 32a rotary isolator but its located 300mm away from the hot tub. Circuit is protected by a rcd and would not be easy to relocate.
Is this totally against regs?
Generally consider it as a swimming pool and you would not be in any danger of a problem, unfortunately that means 2m away from the hot tub for 230V switches.
If someone gets a shock from it in the future, who would be liable for that? I think the isolator was fitted and then a hot tub company installed the hot tub at a later date.
Presumably if there is no where else to place the isolator, the hot tub company would say that they are doing the best they can in the limited space and that the provision of IP44+ rated switching and 30mA RCD protection should avoid a deadly situation. There do not appear to be specific regulations for hot tubs so it would be hard to prove liability for an electric shock based on the install you describe.
Then not to worry but remember when the invitation to the ‘pool party’ plops through the letter box, tether yourself to an earth spike!
We were planning on using this job as an nic inspection prior to another company installing the hot tub supply. Would nic fail you on that because its closer than 2m?
You did not install the supply so they cannot fail you for something someone else has done.
Just tell them your concerns about this later addition if they ask, but since you have not been paid to resolve it there is nothing you can do.
Though having some options for solution may indicate that you have thought about it.
