Discuss How are fuses installed in this isolator in the Commercial Electrical Advice area at ElectriciansForums.net
What I do, and presumably others do, if you don't want it energised is to remove the carrier and hide it somewhere locally.
You'd need to find out who removed it and why.
That isolator was made redundant due to a new cabinet being installed in the extension of a new school. As it's still wired up with a busbar chamber we were looking to use it to supply another building. I will see what I can dig up.
The Permit as mentioned above normally has a DOI listing all isolation points and information on who did the work etc etc...
So if a Permit was required to remove and carry out the work it will probably require the same to re-energize or modify, you need to contact the Safety Controller (Permit Issuer)..
Reply to How are fuses installed in this isolator in the Commercial Electrical Advice area at ElectriciansForums.net
Evening, I've been asked to install a supply to a sprinkler system in a new installation that must be separate to the building electrical...
Hello All So I'm not long out of my college days and unfortunately I didn't have a lot of exposure to three phase and commercial wiring systems...
Hi all, if I cannot access the line side of a crabtree 100A DP main switch. Would someone enlighten me how to conduct safe isolation on this...
Hi there, Any advice on this would be greatly appreciated! (Note, this is not a DIY, I'm using a fully qualified electrician, just posting here...
Hi we have been asked to run a 3 phase supply into a boiler house to feed a DB fed from next to the existing meter. Would we need to install Tails...
