B
BES
Hello
When to price job today bathroom lighting and fan looked at job no problem. Asked customer where cu was in brand new kitchen i asked who done electrics got told kitchen fitter arranged electrician. Looked at cu 16th board looked again the busbar hadnt been cut !!! so it was attached to main isolator and rcd. Explained to customer the problem and tested rcd to show her it would not operate due to how the busbar had been fitted and the dangers due to this she said electrician doing kitchen never said anything . Asked if he had left any paperwork or certs and if any testing had been done oh what a suprise nothing. The new cables in cu so called electrician had put in were that long you could have put a exra rfc and no bonding to water in kitchen. Explained part p to her and what sould have been done telling her hope the work he has done is ok as it may involve dismantaling her lovely new kitchen .Advised her to get kithen fitter back and ask him why no testing was done and no certs issued and if electrician was qualified and registered to do this work.
There needs to be tv/radio adverts like they do for Corgi (gas) to make sure customers ask for a Part P certified spark. Ohhhh the dangers are equal to (if not worse) than gas
I disagree.
When I was working I was qualified to and worked with BOTH electricity and gas in domestic & small commercial properties, and trust me on this: if I made a mistake on the electric side of things I could kill someone and / or set fire to a building, but if I got it wrong with gas, I could literally demolish a whole terrace and kill not only the occupants of those properties, but passers-by in the street outside.
I disagree.
Also to note electric faults usually have done the damage before been discovered but gas has an odour introduced to it that everyone knows... the casualty rate from gas explosions in domestic is miniscule compared to electrical deaths and injuries, the explosion risk gas has attached to and the sheer scale of damage it causes has meant the industry saw early safety reg's brought in but the only time a shake up of the electrical industry saw was when a MP lost his daughter due to out of zone cables in the kitchen which killed her..... its not what you know its who you know and welcome the highly flawed Part P that was thus introduced.
I can make a bigger bang than you can .. so there !! nernernenerner :prrr:
:wink_smile:
When was the last time you saw a TV ad for Corgi/Gassafe? I've never seen one.
I've seen lots from BG pushing their "services" but never one from Corgi/Gassafe
Why this has beed branded as part P is beyond me. Should have been Electrical Safety Certificationd at Home or something like that. Majority of the public doesn't know what a building regulation is, not to mention a part P. Electricla Safety sounds more dramatic, bit like Gas Safety.
I am a plumber and to be honest you sparky's need 1 governing body instead of the several different ones, it is so hard to look up each electrician, then you could all be governed and promoted by that company
The the very last thing you want to govern the Electrical Industry, is a another ''Private Company''. It needs to be at the very least a sudo government affair with Real Teeth, and with Real minimum Standards. All private company enterprises will only operate on a maximum profit for minimum input/outgoings...
Did you know that this week is 'Gas Safety Week' and is being promoted nationally by Gas Safe?
I thought not!
how do these cowboys get away with it
BES,
sparks1973,
