A
assegayer
Hi
I have a question i cant seem to get an answer too.
If you have a portable generator and you plug for instance a fridge or any appliance directly into it, how is the neutral/earthing provided??
I know already that normally you can connect the neutral and earth from an existing installation
But what if you are for example somwhere random and i plug a fridge into a generator where is the neutral coming from? Surely it cannot be from the casing as if someone was to lift the generator up they would get a belt from the supposed to be neutral return path?
Thanks in advance
Thanks in advance
