Discuss How to bodge up a deliberate mistake in the UK Electrical Forum area at ElectriciansForums.net
Came across this while doing remedial work
but that 25mm? bit of tail is just linking 2 MCBs that have no L feed.
But it really begs the question "why?" as there are surprisingly few circuits for that size of CU and one wonderes what the 32A non-RCD feed with two cables was needed for.
Assuming it's a house, and those two are a RFC I still think someone ran out of bus bar or cut it wrong and this was their hack. Either way plenty of questions, as why not just swap an unused breaker.....
UNLESS there is an earth fault on the RFC....
Also seem to be not enough neutrals conductors?
Reply to How to bodge up a deliberate mistake in the UK Electrical Forum area at ElectriciansForums.net
i have faild napit annual assessment with silly mistake of using on consumer unit type AC rcd instead of Type A rcd. i bought type A rcd but they...
Does a SPD need a dedicated way? I need an extra way in this unit for a 3 phase car charger As you can see its a small unit with no extra...
Had a customer message me before I went to do a job asking if I could put a new bulb in a spotlight while I was there, so I picked up some LED...
I'm interested how you would all approach this one. A 3 phase distribution board on a caravan site, under lock and key. Only warden and manager...
