Discuss How to bodge up a deliberate mistake in the UK Electrical Forum area at ElectriciansForums.net
but that 25mm? bit of tail is just linking 2 MCBs that have no L feed.
No, it runs from the outgoing main switch L to the infeed of that B32.
But it really begs the question "why?" as there are surprisingly few circuits for that size of CU and one wonderes what the 32A non-RCD feed with two cables was needed for.
My money is on a board change from a Wylex standard, sparky had stocked up on a few of those CUs when his wholesaler had them on a FGS-won't-somebody-buy-them offer, he didn't do any testing first, when he found that the RCD was tripping he hurriedly moved the neutrals, hacked the end off the busbar, bunged in that bit of tail and rode off home for tea.
UNLESS there is an earth fault on the RFC....
Roll up, roll up, place yer bets....
Also seem to be not enough neutrals conductors?
Looks that way. Must be a camera angle thing though?
fedora or kia-ora? mate of mine wore a steston , mind you, he was a bit of a cowboy.
The breaker fed via the double covered tail is not RCD protected.This will be a case of a fault on this circuit that kept tripping the RCD so the 'electrician' bodged the wiring so that the circuit stays on when he changed the consumer unit rather than fault find the circuit.
Reply to How to bodge up a deliberate mistake in the UK Electrical Forum area at ElectriciansForums.net
i have faild napit annual assessment with silly mistake of using on consumer unit type AC rcd instead of Type A rcd. i bought type A rcd but they...
Does a SPD need a dedicated way? I need an extra way in this unit for a 3 phase car charger As you can see its a small unit with no extra...
Had a customer message me before I went to do a job asking if I could put a new bulb in a spotlight while I was there, so I picked up some LED...
I'm interested how you would all approach this one. A 3 phase distribution board on a caravan site, under lock and key. Only warden and manager...
