Can someone out there help me please.
The front of my house has horizontal upvc cladding and aluminium window frames in hardwood surrounds which will be coming out and replaced with upvc frames ie. no more hardwood to fix into.
At the moment a telephone cable connects to the house and drops vertically down being clipped to the hardwood frames.
Once the upvc frames are installed there is no way I’d want the fix using screws or nailed cable clips.
Also at the moment the cable drops straight drown and goes through a hole drilled into the wood and into the terminal box in the house.
Questions:
Is there any sort of UV resisting plastic the phone wire can run inside?
What would be the best way to fix the cable enclosure to the new upvc frames?
What would be the best way to seal the top of the enclosure to prevent water tracking down the cable and into the terminal box inside the house.
I understand there should be a drip loop on the cable which there isn’t at the moment and unfortunately there really isn’t enough spare phone wire to create one so I think I would have to settle for that.
Maybe it would be a good idea to leave the bottom of whatever the cable is running open?
I won’t be fitting the windows myself but would like to know the best way to instruct the window fitters how attach the cable, although I’m hoping they have across something like it before.
As far as the phone is concerned its not big stuff, its about 4 to 5mm diameter so I’m talking about steel wired armoured with huge brass glands.
Does anyone have any ideas and maybe post some links on what I could buy to pass onto the fitters doing the job, or a least discuss it with them when they come the measure up and quote?
Again my thanks to anyone who can input to my questions.
Questions:
