Search the forum,
Discuss How to get network cable up/down cavity? in the UK Electrical Forum area at ElectriciansForums.net
I realise putting mains cables in a cavity is a no no but I need to get a cat5/6 cable from downstairs to upstairs in a dorma bungalow and thought the cavity might be a good route?
So does anyone have any tips to get a network cable through a cavity?
Cheers for any help.
Forgot to say the cavity has no insulation.
^^ transfer rates are affected by RCD's, so if the 2 adaptors are on the same circuit then they should be OK.
As for expensive - not sure I agree
Why not use outdoor grade CAT5 and run it up the outside?
Cheers all. Think I will go for outside cat6. It will be nice and reliable and fast.
Circuits are on different RCB's so not great for speed.
The 1200Mbps seem to be over £100. Where as exterior cat6 cable is about £10 for 10 meters.
Drill a hole on an upward slant, push up some rods and then in the loft space attach Cat 6 external grade and pull downwards. I have had had varying degrees of success and snapped a few pull rods in the past, but always worth a bash.
The trick the cavity wall lads use when brushing off a cavity to next door is to drill a hole at the top, drill a hole at the bottom perfectly in line then feed a chain in through the top hole and fish it out the bottom hole with a wire coat hanger with a small hook formed into it....Naturaly the chain drops in a straight line due to the weight. Not that I'm advocating you use the cavity but sometimes needs must. ;)
I have powerline adapters in my house. Had no problem with them and think they are great for what I need.
Not wanting to state the obvious.... Just make sure the house doesn't have 'cavity wall insulation'. Will defo change the way you do things.
Reply to How to get network cable up/down cavity? in the UK Electrical Forum area at ElectriciansForums.net
