Discuss How to open this holder? in the Lighting Forum area at ElectriciansForums.net
The two halves lock together when assembled and are designed not to come apart again.
Just cut the cable after safely isolating and locking off the supply
Thanks but need to remove it from the clamp to fit a new one. Do I just "break"the unit?
The cord grip should unscrew from the lampholder, and it looks like that is all that is holding the lampholder in place
£3.00 to replace, save your knuckles.
Remove bracket, the one linked comes with a bracket, sorry not very clear.Sure but need to remove it from the bracket first. Have got the replacement already.
If you look at the outer edge of the metal ring that the build lugs fit in to Ullapool see a bit of the metal the ring is made of where a bit of it sticks out and it grabs against steps in the plastic bit ull need to bend it inwards to stop it gripping against the outer bit
E27 Porcelain Lampholder with Bracket [PLU66971]
Buy the E27 Porcelain Lampholder with Bracket from lampspares and many more lamp holder accessories to help build or repair your lamps at the best price.www.googleadservices.com
My that's a big one
Many thanks will try it out. Is this a common - to "fuse" it at the production time?
Thanks a lot. Will have a go.Sorry about the quality of pic
Looks like this mate
It's not fused tigether, the lampholder is screwed together and a little metal tab locks it a bit like a ratchet mechanism. It is possible to get them apart again if you can get to the metal tab and push it back, but it's really not worth the effort if you're replacing the lampholder anyway.
Reply to How to open this holder? in the Lighting Forum area at ElectriciansForums.net
