_q12x_
One of the original objective for this projekt was to be as FLAT as imaginable. I originally wanted to be flat as a piece of paper or as a paint thickness. Thats like 10micro. But in reality, we have the leds height that add to the board thickness and the other components heights. As you can observe, absolutly no stand up component (or vertical placement), all are horisontal placed to diminish the thickness of this board as originally intended.I thought you could put a cover over the board with the modules on. But that would obscure the LEDs. What you could do is use the light pipes to take the light from the LEDs from the wings moduleto holes in the cover so they could be seen. The light pipes have flat or rounded ends. You as an artist could then design and draw the wings on the cover around these light pipe exit holes.
I think I understand your point. Because the other components height, I should add these tubes on the leds to get them more in front. Is this correct? Well, it is a nice idea, if I want to cover all the electronics and not use this transparent cover. But the thing is that I want to show all those wires there, all my work. I want to show it is a prototype, because it is.
Yesterday, ALL day, I built the receiver circuit Module. Today I finish it and it works ! Youhoo. Next, is to make the transmiter.
