Discuss I dont know what its called but I need one in the Electrical Tools and Products area at ElectriciansForums.net
the pict
Mentor
I have a metrel MFT and my spiral lead has gave up ..... so what kind of plug is on the machine side it must be called something ...as I want to make up my own
Pict
Is this it @the pict ??
I've got metrel and I looked long and hard for this part with no success ..... the replacement leads are no longer curly!
I can't seem to find the '4 pin special Metrel connector' anywhere as well.
Still looking...
Metrel are taking the pxss ...................................
that said my existing one has been in use a long time ................. so better quality than the curly one!
ill check my emails and post later, I ordered from a site recently and they stock literally every connector going, you could knock your own lead up using some curly flex as we will call it and a plug.
Have looked and it seems metrel had the 4 pin adaptor thing made purely to be awkward.. its essentially 4 banana adaptors as they are known on other leads/mfts in one. it means you can only use there approved stuff, although some in the far east started knocking them out. you will if you look hard enough find the adaptor, then using some wires and readily available banana adaptors make your own, but given the time to locate bits, might be cheaper to buy one.
I've just gone through the CPC catalogue and can't find one in there. Hopefully you will have better luck.
Reply to I dont know what its called but I need one in the Electrical Tools and Products area at ElectriciansForums.net
im not sure where to post this.. and I need help [ I posted here because i guess Heating systems may need a hole this big , and this is the only...
I have a bathroom fan with a moisture detector that turns it on and off. It also has a control circuit to turn it on/off when moisture is not...
Maybe I've just been lucky, but I very rarely have an issue with customers paying, the vast majority have paid straight away or within a few days...
I'm unsure if I should be an electrician or maybe another trade is better. I have basically completed my first year of a foundation in...
Hello fellow sparks, I’ve decided to go out on my own. Recently bought a little van and trying to get myself set up whilst keeping my costs as...
