P
Powerhouseelec
Got asked to day to quote for a "strip light" around three sides of a serving counter in a Chinese buffet. The area has a big commercial extractor hood, he either wanted lights along side it or on it. It drops down from the ceiling about 300-400mm. I don't want them on the hood so I suggested a suspended track. Its going to be 1 metre 90 degree bend 3ish meters 90degree bend then 1 metre or I have a price on GU10 fittings that drop down 315mm from the track on the ceiling rather than suspending the track. Does anyone have any other ideas ?
As it is a commercial Kitchen I would suggest T5 lighting, you can get it which looks pretty attractive, not sure what the budget is, however ask your local wholesaler for some ideas.
It has a hood similar to commercial kitchens, but its out in the main restaurant. I think he wants to light up where they put the dishes of food etc. Im not sure on the budget either really just a track with 5 GU 10s is going to be £340 with VAT but I thought he can add more lights easily later if he wants.
sounds a bit dull though, what's the lux requirement? or is it up to you to guess? find out if he wants a decent lux level or a lower comfort level. if you get it wrong it could be a can of worms, I know, I do this for a living and have learned that thought into customer requirement is paramount and not a "guess that will do" don't take that the wrong way I'm on your side, a bit more info needed though Fella.Mike
We have a indian up the road that has a similar GU10 set up but it uses LED lamps that change RGB and looks very nice :)
Maybe some lecessed righting would look good with colour change option RGB
I see you are really getting into the Chinese approach with your lecessed lighting!
I would have thought suspended LED rigid strip might be quite good they come with 90 bends as well. Colour changing if you want.
Ideas for chinese buffet lighting
Powerhouseelec,
Richard Burns,
