Discuss ideas please in the UK Electrical Forum area at ElectriciansForums.net
S
sparky-s-w
hi guys/n girls
had a call today from a local farmer, "ive fitted a new flood light and connected it to the an origional feed", "but it dont work".
(apparently he did some electrics in the navy)
ME:-ok its either a faulty light, or the feed, ie damaged cable fuse triped etc.
FARMER:-"i checked the feed, at the connector block (junction boxs on post) got 215v" "but when i connect the light fiting then test i get 20 something volts"
ME:- Please leave it be, ill pop round thurs/friday.
now i've not seen/been so just trying to pre-empt the job.
any ideas, assuming what hes saying is true:rolleyes2:.
I would have thought a poor neutral or even a poor line connection giving a low voltage under load, did the old light work? Re the 215 even if it were a long cable there should be a decent voltage until there is a load, try testing to CPC assuming there is one.
yea thats why im thinking a new run, damaged cable might explane why the sudden loss of voltage under load.
prob no earth, he said the cable is SWA ran underground to a post
Reply to ideas please in the UK Electrical Forum area at ElectriciansForums.net
Hi there :) the light switch for a ceiling light needs to be pushed quite hard in order for the light to turn on. What started happening first was...
9K
Hi Guys & Girls, It's been a while, hope everything is good. I have an issue that's proving to be a bit of a head scratcher. Please bear with...
Just finished installing 20 x spike lights in a customers front garden. 2.5mm SWA ran from existing junction box feeding existing fence lights...
I am an old school Leccy having done 24 years in the Royal Navy as an electrical/electronic engineer (Control Electrical Mechanic) maintaining...
S
Hi people Maybe somone can give me some pointers, Generally with faults i'm pretty good but this one has got me stumped! I was working in an old...
monkeyelectric
M
