Discuss Identify this head unit in the UK Electrical Forum area at ElectriciansForums.net
leebut
Hi guys
Came to do the testing on small bathroom lighting job today and I was confronted with this old piece of scrap iron.
I’ve never come across one of these before, so I’m asking you guys for confirmation of what I think what it is I’m looking for the type and BS number and amperage, so I can fill out my certificate, my thoughts are it’s a Bs 3036 semi enclosed rewire able fuses and guessing the fuse wire has been upgraded in the past from 30 amp to probably 60 amp.
I’ve already told my customer that they need to contact Electricity North West to have the head unit replaced as soon as possible for two reasons, the Bitumen has tracked back into the head and the live fuse is fully enclosed in the bitumen at the bottom and cannot be removed and the second reason it’s a fused neutral supply that’s no longer allowed be installed.
AED228EF-6622-4231-A3B2-35A545E7E6E9.jpeg47EFC034-F9EE-42EB-A524-87B38C865B26.jpeg9741A3DE-B35D-440A-AF5A-36A2F6105A7E.jpeg
Cheers
Lee
The bitumen wouldn't be my first worry. Beware asbestos flash guard pads.
Also if there's a fuse in the neutral it should be removed and a blank inserted although this would probably be a job for the DNO.....
Finally I wouldn't mess that incoming cable or the earth wire that's attached even if it does require upgrading. That type of cable is usually fine until it's disturbed, at which point all bets are off.
I’ve already told the customer to get in touch with the DNO I’ve no intensional of touching anything in the head unit I just need to finish my certificate so I can register the installation, there was no seal on the front of the head unit I only opened it up to see what the Bs number was
Hi guys
View attachment 50335View attachment 50336View attachment 50337
Cheers
Lee
Wrong forum Mate if you specialise in Bathrooms!
Retrained in 2004 now qualified spark as well as my original plumbing background.
Fully qualified with city and Guilds for 16th, 17th and 18th edition of wiring regs as well as city and Guilds qualified for Electric Vehicle charging installations.
I was only installing lighting and a fan on this bathroom bud
Wow
I’m only after a simple answer to valid question, we all come across things we’ve not seen before, if your bothered about my background in electrical work check my Napit page out (3862) how long I’ve been a member with them since 2004, I don’t get what the problem is??
No problem Mate, you said you are a bathroom specialist, or more to the point your profile does, and I thought you are a Plumber, never questioned your electrical quals, just surprised that's all, you're the one getting all wound up.
Hi Pete
I don’t go and check people’s profiles out when I reply to people’s questions, I just answer the question if I can, I filled my profile in numerous years ago, I will this evening change my profile to a more appropriate profile, things have changed in a big way regarding my work, mainly electrical work now, but every so often I do have a dabble in the bathroom work for previous customers
I jumped on the defensive regarding my electrical background because I’ve had people slag me off in the past because people think your below them because I’ve come into a second trade etc
that my friend is one thing you should not play with ,considering you where testing a small bathroom light .the question why did you open it .
I opened it because there was no seal on the head unit and no marking on the outside to give me an idea of what the Bs number was
I’ve done nothing illegal, my iCertifi certificate software asks for the Overcurrent Protective Device BS number, type and rating, someone previously has installed a 17th edition split load board in 2012 the house owners have just bought the property and have no paperwork for the installation.
I took a look inside and to be honest I’ve done my customer a favour as the fused neutral head unit needs replacing as previously mentioned in my original post
It isn't always the case it would be a DNO fuse. What do you normally quote for a sealed head.
If the seal has been cut previously by another person I take a look
If it’s sealed it stays sealed and “unknown” is recorded on certificate, I have been question to why I haven’t noted the info on my assessments in the past
If it’s a modern head unit that says 100amp on the side or has Bs1361 on it I record that, or if I know what is normally in the cut out from previous installs I put record an educated guess??
So the same question back at you what do you record on all your certificates you can’t leave them blank on every one,
I posted a picture of a head unit that was similar to this one a couple of months back where the bitumen has seeped out of the old head, when the DNO had been to replace the head with a new unit they didn’t actually put a seal on the fuse, that might have been because the customer had told them I was going to be fitting a new consumer unit a week later and I’d asked the customer to get the DNO to install an isolator switch which they told the customer they don’t do
You can't be guessing or noting what the carrier has written on it. Without physically seeing it you must state NV. If anyone queries this tell them the head is not part of your remit to be interfering with. To be honest this info is generally irrelevant.
To be fair, if it didn't have a seal then I would have had a little peak. Wouldn't touch though.
I didn’t touch it, as soon as I opened it I saw the asbestos flash mat and the label looked suspiciously like asbestos too took a photo and closed it back up.
I knew straight away it needed replacing because of the fused neutral supply and the bitumen encasing the lower part of the fuse carrier.
I am amazed the guy who did the board change back in 2012 didn’t notify the DNO to get it updated
Reply to Identify this head unit in the UK Electrical Forum area at ElectriciansForums.net
So I just started out recently and I’m struggling with what to price myself at. It’s worth noting I live in the east London area and I’m looking...
I’ve had a disagreement with one of the Engineers in work. So we are doing an install. Installing an Intruder Alarm. Rather than go with my...
5K
Looking for some cabling advice for my garden project. I’ve put together this diagram below, which hopefully explains what I’m trying to achieve...
Evening all. I have a question as I can’t get my head around something with solar PV I’m going to be working on a new build in a couple of...
Hi guys I’ve got a motor starter I’ve come across and looking at the electrical drawings it’s originally had 35mm tails from a 100amp fused...
