Discuss Identify this head unit in the UK Electrical Forum area at ElectriciansForums.net
You can't be guessing or noting what the carrier has written on it. Without physically seeing it you must state NV. If anyone queries this tell them the head is not part of your remit to be interfering with. To be honest this info is generally irrelevant.
Fair enough I’ll just put NV from now on, if I get questioned again on my assessment I’ll explain why I’ve noted on the certificate as NV
He maybe did notify the dno but because of the daft setup with suppliers chopping and changing things get overlooked..
Also meter readers should be observing and reporting substandard kit..
Any paperwork from the consumer unit change?
Customer didn’t have anything the other day when I asked but was getting onto their solicitor to check why no paperwork was available on purchasing the house
All these comments about me opening the panel and still no one has actually confirmed my suspicions of what the BS number is and what the rating could be
I think solicitors check whether here has been a Part P notification
If there has been a notified job they then request the certification
If no job has been notified no cert request because its a unknown
Part P seems to be irrelevant except when there has been a notification made,no notification no problems are encountered
Bs3036
Could be any size fuse wire that fits
Cheers for confirmation I thought it would be the 3036 but wasn’t sure that covered the incoming cut out as well as a old Wylex board it says in the lid 30 amp but possibly upgraded years back with either a 4” nail or a 60 amp piece of wire :eek::eek:
In this situation I email or phone the dno and submit a form to request upgrade..
I am in a lucky position though as over here in the iom we only have 1 dno and I’m on 1st name terms with all their staff who have a great rapport with the electrical trade..
You'll probably want to record it as BS3036 but it actually pre-dates that standard by a few decades. I would generally not recommend opening CI cutouts. If anything is loose or broken inside, there is a much higher risk of short-circuiting the incoming service compared with all-insulated units, with resulting nasty arc flash. The supply impedances are often lower now than when they were installed (this one could be 90 years old) so their designers were not anticipating the kind of fireball that can occur today when blowing a 315A substation fuse.
That said, if anyone comes across disconnected / redundant ones, I need them for the collection.
Wish it was as simple over here bud I asked if the DNO could put an isolator switch in a couple of months back they said we don’t do that, so my response was how do I perform safe isolation then, they said we’ll get back to you, still waiting!!
cheers for the info
Rung em last week over here for a main fuse upgrade and got told can’t talk talk to you need the homeowner, I had to write the homeowner a script as she had no idea what to say to them
Just mark it down as 'obsolete' else Not verified or not known. Mark the certificate as it needs sorting by customer and DNO. Get paid and walk away.
Exactly the problem I had a few weeks ago so I told customer what to say to get it changed ASAP
Total opposite over here..
Customer only signs the form to pay the bill, we do everything else, saves so much hassle..
Reply to Identify this head unit in the UK Electrical Forum area at ElectriciansForums.net
So I just started out recently and I’m struggling with what to price myself at. It’s worth noting I live in the east London area and I’m looking...
I’ve had a disagreement with one of the Engineers in work. So we are doing an install. Installing an Intruder Alarm. Rather than go with my...
5K
Looking for some cabling advice for my garden project. I’ve put together this diagram below, which hopefully explains what I’m trying to achieve...
Evening all. I have a question as I can’t get my head around something with solar PV I’m going to be working on a new build in a couple of...
Hi guys I’ve got a motor starter I’ve come across and looking at the electrical drawings it’s originally had 35mm tails from a 100amp fused...
