O
Olec
Hi there guys and girls, hoping you can help me.
A while back I did a cu upgrade and some accessory changes for a property that was being let. It had at some point been part rewired and all cable in the cu were t&e copper but some of the lighting and switch drops were wired in what I thought was tinned copper. All my test results were fine.
Since then iv'e done a bit more research and found this ali cable that is apparently much more risky and needs to be rewired if found.
Can anyone help me identify the differences between these two cables for future ref?
