Discuss illuminated shop sign in the Electricians' Talk | All Countries area at ElectriciansForums.net
K
KNIPEX
i have been asked to have a look at an illuminated shop sign, as it looks like some of the tubes have stopped working in it.
anyone know how these signs come off how you get access to the tubes???
is the a nack to getting them off etc??
dont want to look a fool trying to get the cover or the insides off.
thanks
Depends on sign all are demountable from the outside , usually the frame is secured by screws , just make sure it's fluro and not cold cathode before you start
There is normally a frame of ally fixed with self tappers which holds on the plastic sign, usually you take off a side and the sign slides out of the frame...go exceedingly careful removing as they are often brittle and the shop doesnt always see the funny side if you break it...if it's a biggun avoid windy days...
taken a few of these down before. about half of them had rivets in them, like the other post said be careful as they can be brittle.
Depending on the frame type, this could also be top hung. Might be a case of lifting the panel and swinging the lower edge out and un hooking the top. Should be 10mm acrylic if good, but as others have said the acrylic will go more brittle if in a prominent sunny location. The max panel length will be just over 3m, anything bigger will be done in bits.
If stuck, post a pic of the frame and Ill try and ID it for you........Im also a sign maker :D
may have a job for you coming up mate if it comes off I will pm you the details of the sign
hi graeme,
i am a sign fitter and electrician, specialising in large flex face and neon installs so if you get anything needs doing over may way give us a shout ;)
thanks
as has already been said if the sign has perspex panels there will be an angle frame that sits in a recess secured by screws, normall panel will have a hanging bar on the top so remove top angle + 1 side and your away.
if its an alumimium tray sign there will be screws top and bottom.
if its a flex faced sign there will be a tensioning system underneath some trims or flaps.;)
thanks
How did you get on? I've been asked to look at some illuminated signage too. Customer says bulbs keep blowing and they want the shop front to be much brighter. So any pointers you can give from your recent job would be very welcome.
They may want it brighter but it can depend upon what the local council says.
hi mate i looked at it but decided it wasnt safe for me to do it on my own due to the size of the sign, the cllient is going to inform the sign company and get us both back at the same time.
Reply to illuminated shop sign in the Electricians' Talk | All Countries area at ElectriciansForums.net
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
Bit of a rant first to explain the situation:- Effing builders again, I knew there was a reason we hardly ever work for them. We've done a few...
Im trying to make a Star Wars Prop for a course project where the dealine is comming up very fast in days and I need to do the report so really...
Hi All, Might be a stupid question but I have about 30 of these smart+guard alarmed call point covers to deal with. All the batteries are dead...
Doing a kitchen job for my daughter’s music teacher, who also happens to have been in my wife’s class at school. Nothing big… just a little...
