Y
YTSOxford
Where would be the best place to put an immersion heater switch. Am working on a bungalow, where the cylinder is being repositioned in the loft. I usually have the immersion switch in the airing cupboard, but am unsure in this case. Is it acceptable to put the unsightly switch above a doorway??? to the utility for example, or should i put it near the boiler itself, which will be in the hallway??? Thanks all.
