A
Andy 4482
hello, having a problem with an immersion heater causing a 16 A RCBO to trip it is definately non of wiring with a fault on as all been tested and powered up without imm connected. have tested imm (3kw) continuity 19 ohms (fine).and insulation resistance to earth >1000 ( fine). i have heard that a imm heater can test out fine but still be faulty under load ? . the only other thing i could think was that the rcbo was faulty but this cct is also powering a small (fused down fan ) which isnt causing it to trip. any ideas ? im just wondering what most likely problem is and what action to take ? cheers
