Search the forum,
Discuss immersion testing in the Central Heating Systems area at ElectriciansForums.net
stidge
Hi lads just a quickie, can anyone advise on testing immersion heaters , What test ? Which terminals etc cheers for any advice . Have had phone call they think immersion is tripping cu !
cvontinuity L-N shjould give around 20 ohms, IR test element to E. pretty obvious, really.
Reply to immersion testing in the Central Heating Systems area at ElectriciansForums.net
Firstly, thank you for taking the time to read this. I am not trained in electrics whatsoever, I am a just a home owner looking for advice. I...
Hi, Have normal fused immersion heater switch. I would like to add a smart wifi switch to it so when my Solar is producing over 3k spare, going...
Hi I am asking for help as a novice and 1st time user of this forum. Recently started to experience tripping of MCB & sometimes with the RCD at...
Hi, Small flat, currently has a small'ish feed water tank, top of a cupboard, feed through a wall into under stairs cupboard. Hot water tank...
Hi just wondering if someone can help me. I have an rcbo that keeps tripping but only when the fly earth and neutral lead on the bars it trips...
