Search the forum,
Discuss Induction hob. in the DIY Electrical Advice area at ElectriciansForums.net
I've seen what has been posted elsewhere and, the advice to the OP is pretty much identical to that here.
The OP seems to be going round in circles because the either don't or won't understand the advice given to them, for free, by professionals who specialise in this area of engineering.
The OP has their own ideas and keeps asking in different ways if they are acceptable and keeps getting told no there, the same as here.
Also using an NC contactor is a crazy idea!!!
Totally dangerous and potentially lethal.
In fact so much so it would be verging on criminal negligence is someone were to get hurt because of it.
All obviously IMHO.
And one more question . Is there anything to stop me running the hob in 3 phase even though I have 3 CU each on a different phase? I was intending having a 20 Amp MCB in each for the hob. The hob is split into 3 zones so I
assumed, rightly or wrongly , that this was permissible.
This is a very very bad idea. Please do not do this.
So 4 pole RCBO fed from the henley blocks with 4 pole isolator by the hob. A simple yes or no will suffice.
If I cut a piece of cable and then just join it together by twisting the conductors together will it work?
Bogart, it's not about whether something will work or not, it's about all the other knowledge required about how it works.
Your questions show that you don't have the knowledge to be doing this so no sane electrician on this site is going to say 'yes' to your question as you'll just blindly take that as a green light.
Will give up as seems impossible for you lot to give a sensible answer. Why did I bother?
close the door on your way out. DON'T SLAM IT. :p:p:p.
Reply to Induction hob. in the DIY Electrical Advice area at ElectriciansForums.net
Hi all, we had our gas hob removed months ago and finally just got round to putting an induction hob in. Its a normal 4 ring induction but one of...
Hello hope you can help I have a single oven 2.4kw max and a ceramic hob 6kw max I would like to put then both on the same circuit so i was...
hi looking to install a new induction hob to current wiring . the wiring i have is thick white probably about 15mm wide and is hard wired into...
Hi all, I’m now ready to install my hob, I have a 32A MCB with 6mm T&E feeding a 50A rated switched supply at the worktop. The hob isn’t supplied...
About 5 years ago during a full refurb on my house I re-wired the property myself (old aluminium wiring) in line with 17th edition. I had it all...
