F
flabbagasted
Hello hope you can help
I have a single oven 2.4kw max and a ceramic hob 6kw max
I would like to put then both on the same circuit so i was thinking 10mm cable from consumer unit to a junction box then 6mm from jb to hob via isolation switch then another 6mm from jb to 13amp fused isolation switch then 2.5mm to oven all protected by 45amp mcb
Is this allowed or correct the built in oven and hobs are on opposite side of kitchen.
Im aware that i will need an electrician to carry out the connections but if i could at least run the wires and have it all prepared.
Many thanks for all replies
