Discuss Inspection champers/manhole for power cables in the UK Electrical Forum area at ElectriciansForums.net
Hello guys
I want to install underground 5 core 16mm cable and Ethernet cable
I want to feed power and data from an old building to a new one.
Just in the foundation phase now so it is good time to install conduit and inspection chambers. Can you recommend a small and compact chamber in the market?
Regards
Stefan
Reply to Inspection champers/manhole for power cables in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm going to be wiring up my garden office with power and ethernet underground and I need advice on the best way to run the cables as I have...
Hi, I need to run a duct from our garage, under the (gravel) drive to the house. Specifically this is for a monitoring sensor needed for our...
Hi all I’m after a bit of advice regarding wifi/secondary router. Data is not a strong point of mine so any advice would be very much...
Hello, hello, long time listner, first time caller... So, I have an issue in a house I'm trying to get ready to rent. The plumber has installed a...
Hello, We changed plans with lighting in one zone. Now instead of 4 downlights (square shape of 1400mm side) we want a chandelier. Since...
