Discuss Installation Routs and methods etc in the Canada area at ElectriciansForums.net
R
revolt3k
Was woondering how others route there cables through joists, do you drill all new if there is existing notch's when doing re-wires cos we do some old houses and there is loads of notches already weakening the joist. Do you use them and use safe plates to protect? Also do you bond all the safe plates?
Another one is running cables in stood wall's, and ceiling's that will be insulated. Like in new houses and extensions. Allot of other sparks i know dont do cable calcs for factors such as insulation and are just running 2.5 and 1mm for any routes. I've started to use 4mm for sockets and 1.5 for lights if in contact on one side but i would like to know what others are doing.
cheers
yes i agree it would be a pain but it does say that protection if of metal should be eathed.
Anyways you didnt answer my questions guys.
Reply to Installation Routs and methods etc in the Canada area at ElectriciansForums.net
Hi All I wanted to ask a question about the reference method. Passing wiring through holes made at 0.2-0.4 of the joist span. The cables passes...
hello, i am just about to completely rewire a refurbished house. i have done the same to several houses in the distant past. i have just read...
Hi all, Merry Christmas to everyone, and apologies for talking work during the holidays😅 I have my first EV charger install job early in the New...
Im in the proces of installing a meter room with 25 meters and riser. Allways i use communal area for cable route from each flats to meter room...
