I
irishsailor
LadGood MoriningDo any of you install lights using a laser?? If so what do you recommend RegardsChris
As a rule I normally use a 14 kW CO2 lazer with quartz focus lens. It takes around .45 of a second to cut a 73mm dia hole through a plasterboard ceiling. The biggest problem is placing the Gold coated amethyst reflector behind the board. I have on occasion cut right through 3 floors and out of the roof !
[h=2][/h]
I have a cheap Bosch green diy one from one of the sheds that has a lock on the laser, that way on a tripod it can be tilted to face upwards without the beeping and flashing to say it is out of level.
It has taken a beating thrown in and out of the van and still goes on.
Just out of interest, if a laser were to come on to the market which allowed you to specify how many points on a ceiling, in what pattern and at specified dimensions, how interested would blokes be?
I would be, especially if you could adjust it on the fly to fit spacing within joists etc. It would have to be less than a ton though or I'll stick with chalk and damp string.
I remember a large office refit just when downlighters new, I wasn't involved in that part thank God but some guys got into right mess with the dust string and it actually came to blows, the ceiling was a right state, looked like an ordance survey map with contour and grid lines, trouble was both guys reckoned they had it spot on
luckly the had not cut any holes as they would never have been in line, and trying to rub it off made the whole thing look like an episode of fawlty towers, eventually they had to get a squad of painters in to do a quick cover job,felt sorry for them as by 5 o,clock they were almost in tears, an old timer on the site was a god send to them next day he had it marked out for them by 10 am, where they went wrong was they tried to mark out squares and put the lights in the middle of the squares
Pict
tape measure and a roll of earth sleeve normally does me!
