Discuss Interlock switch, not powering all of my breakers in the UK Electrical Forum area at ElectriciansForums.net
Jason W
I have hooked up a 30 amp interlock switch to my main panel run off my generator. However, only my light switches work none of my plug-ins have any power. Any input would be helpful. Thanks.
Honestly in this case I think that getting a qualified electrician in to survey what has been done so far and the best way to fix the problems is the best way forward.
There is a lot more to running a generator and using it to power a house than you might think, even if what you rig up "works" then it may still be dangerous.
Have a professional look at it PLEASE.
It sounds like you are just getting 120vac instead of 240vac. Check your cord, and plug connections.
I know. But Megawatt said
“ It sounds like you are just getting 120vac instead of 240vac.”
Surely a Canadian (or. USA) genny would be expected to produce 120v. ??
Confirmed by the OP
Most installations are two-phase (split) 120V - 0V - 120V so it you do the simple and obvious you only get half the panel powered up. To run a typical USA house fully you need a generator has 120-0-120 out and a suitable transfer switch for both L and some means to deal with N.
They typically have PME supply with local Earth rods linked to the incoming point Earth/ground, and the N-E link inside the first (main) panel. That is unlike UK where linking N & E is only permitted on the DNO side before your meter, etc.
Presumably then you can switch the main panel incoming L1-N-L2 to the generator's output, with the rods still linked at the panel to earth-reference N while on generator. No idea if that meets NEC code!
Reply to Interlock switch, not powering all of my breakers in the UK Electrical Forum area at ElectriciansForums.net
Hello, First of all, thank you in advance for any helpful insights posted in response to my question. I have just moved into a new home. With...
I am beginner with electric work and do DIY's only :). I installed interlock kit and cut the piece to make it work but electric inspector came and...
I am interested in having a home generator that would provide power to my home when the power is out during hurricane season, etc. I have 2...
My house had previously been wired for a generator (probably not by code to this day) but previous homeowner disconnected and instead hooked up...
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
