Discuss Ip4x cant get 32mm grommets in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Iona222
Trainee
Would you guys recommend using a fire sealant to cover a hole on the the side and top of a
consumer unit, I've cant get a 32mm grommets anywhere. Thanks
Tool station sell them
Bag of them on my shelf - as easy to find as a sheep in Llanelli
where's the "beautiful" emoj?
Made about 9-10 gallons last autumn, the old boys around here have a saying that it's ready when you hear the first cuckoo in Spring. I've been late getting it bottled up this year due to moving house so it needs another couple of weeks in the bottle before drinking as you add a tiny bit more sugar to it as you bottle to kick the residual yeast into life again and re-ferment in the bottle to give it some sparkle. Slightly poignant actually as this is the last batch from the trees at my old place - waiting to see what the trees in the new place produce later in the year but they've been let go a lot so might need a cherry picker in to harvest them as they're so tall ?
cherry picker? suerly an apple picker. save the hire cost. send up an apprentice or 3.
can't beat Addlestones cloudy on draught. my local use to have it. orders 2 x 10 gallon keg per week and there were only 2 of us drank it. sadly my mate cast his mortal coils and the landlady had to reduce the order to 1 a week. still ran out on a a Friday though.
Red Dwarf cider??
I guess the Lister tastes of curry, the Kryten is a little metallic, the Rimmer is a bit weak and hard to stomach... And the last one tastes of cat pish.?
Was a spur of the moment thing - we introduced mini-me (10) to Red Dwarf over lockdown and rather than giving the barrels numbers I just stuck a name on instead. Actually...... this now has me thinking..... "Smeg-Head" Cider as an alternative name certainly has some brand appeal....
Reply to Ip4x cant get 32mm grommets in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Hi does anyone know where I can source any larger round grommets ? I will be drilling a hole in 100 × 100 trunking so guess around 75mm hole. I've...
I’ve always been alright with the knockouts provided for Fusebox consumer units but I’ve got a job coming up where I don’t want to use the large...
I collect old Electrical Fittings and I recently acquired this vintage Junction Box (photos attached). I've been trying to figure out how it would...
I don't think I have worked with 32mm conduit before. Always 25mm and 20mm. I want to contain 2 x 25mm tails and 1 x 16mm earth in some 32mm...
Does the consumer units top knockouts need to have stuffing glands installed even if a 50x50 trunking will cover the holes? Or is it sufficient to...
