Discuss Is it legal for a master electrician to pull a permit for someone else? in the UK Electrical Forum area at ElectriciansForums.net
Hi,
Is it legal for a master electrician to pull a permit for someone and not doing the project in Texas?
Yes it is illegal, that’s called loaning your license which you could get in a lot of trouble. I have drew permits for other home owners wanting to do their work but I showed up every day checking his work which you have to do. It’s your license on the line and if you just draw a permit and something bad happens you will be fined, loose your license, and possibly go to jail. You are the one that has to call for a final inspection so you better know that the work is done by the NEC standers. Show up everyday
Reply to Is it legal for a master electrician to pull a permit for someone else? in the UK Electrical Forum area at ElectriciansForums.net
Hi. We live in an older house and we are doing a loft conversion. We do not have an SPD on the connection to the grid and the builder's...
5K
Hi all, After some help here. My boss at the company I work for is adamant that I must remove my electrical isolation, even though I don't deem...
Hello. German electricians, in my opinion, are quickly vicious in forums, like many German craftsmen, when you ask questions about their area of...
Hi guys, I've gotten AI to write up a terms and conditions for my company and then went through it with AI and tweaked it to make it sound a...
I am looking at installation of an architectural dimmer, that is will supply 6 channels, with 20A circuits each (2400W ea). Our hall has can light...
