Why not gland into a galv. Coupler then fit bush and banjo in box?
Am I right in thinking you have made the gland off into a plastic reducer of some kind that is then screwed into the box?
If so take it out of the reducer and gland it straight into the box.
Also looks like your sheath is split??
Is this within the regs? I can't get the thread of the gland through the box to get the banjo inside. I wanted to use the swa but if not will rely on one of the cores.
What are you saying here, that the box is too thick to get the thread through and get the banjo on?? If that's the case you need to purchase a long reach gland, or fit an adaptable box below to the enclosure, and gland the SWA to that. Or is it that the hole size isn't big enough for the glands thread to pass through?? If so use a suitable cone cutter to open up the hole. BTW Piranha nuts make a much better earth connection that the standard Banjo job....
Having another closer look at your photo, it looks like you are using a plastic gland/fitting of some sort, so god knows what you're playing at here.... Anyway as it stands at the moment, you're installation does not conform with BS 7671...
The thread does not reach high enough into box to be able to put banjo over. The gland is screwed into the screw thread of the box. I have removed the external crimp and cable.
I am trying to fathom out why it should be any sort of a problem whatsoever
The question I ask is "what has actually been attempted to get to that horror show in the picture in the first place"
Then,why even dream of considering it acceptable
Sorry to say,but it seems as though a solution is being sought to a problem that was created in the first place by poor installation practice and experience
im confused?
the 20mm thread is for stuffing glands.
get a cone cutter to widen it slightly then connect it.
if the thread goes inside cut it with a knife.
or do what should have been done jn the first place and chosen decent gear
im confused?
Got there in the end??
im confused?
Or just get the brass earthing plate designed to go in those boxes which the gland threads into and has an earth terminal to connect your cable to.
I hope that the swa is not being used as the earthing. There is no way that you have a secure connection as it is. Sorry to sound harsh, but if one of my 1st year apprentices showed me that, I would tell them to do it again.
I'm at a bit of a loss as to why you couldn't do this in the first place, ...still you're there now!! Bend the tag of the Banjo up and you'll get a better flat connection with the locknut!! Still say you'd be better off with a Piranha earth nut mind... lol!!
looking at that pic., i would say a locknut under the banjo would make for a decent connection.
Yes, what is under the banjo? Not good if it's plastic! I'm not very convinced by the crimp terminal either, nuts in the wrong places, easy for the screw to loosen.
