Is this within the regs? I can't get the thread of the gland through the box to get the banjo inside. I wanted to use the swa but if not will rely on one of the cores.
What are you saying here, that the box is too thick to get the thread through and get the banjo on?? If that's the case you need to purchase a long reach gland, or fit an adaptable box below to the enclosure, and gland the SWA to that. Or is it that the hole size isn't big enough for the glands thread to pass through?? If so use a suitable cone cutter to open up the hole. BTW Piranha nuts make a much better earth connection that the standard Banjo job....
Having another closer look at your photo, it looks like you are using a plastic gland/fitting of some sort, so god knows what you're playing at here.... Anyway as it stands at the moment, you're installation does not conform with BS 7671...
