OK, thanks. So, I'm assuming the ammeter should be showing zero (neither charge or discharge) most of the time, after it's had a chance to recover from starting the car. If it continues to show the system is charging for a long period of time, it's either a failed AGM battery or the alternator's internal regulator circuit has failed. Is that right? If the battery is tested and is fine, I need to look at the alternator.
Sorry, really not good with electrics!
As long as you are sure you all the leads and earth's are secure and the battery is actually receiving the charge; as in @telectrix description , the ammeter would not show high amps at rest with no loads like air conditioning etc.
Do you have a battery to replace for a quick comparison .
Are the alternator drive belts tight , or is it having to work it's guts out.
To be honest it could be one of many things.
Yes, I have a decent used lead-acid battery I can connect up and see if that makes a difference. The belt system is simple - just one v-belt round crank pulley, water pump and alternator. No air con, p/s or anything else. The only item consuming power on today's drive was occasional running of an electric cooling fan, but as the drive after the engine stopped was all on motorway that didn't cut in.
And the belt is running free ? No resistance from the water pump?
Try the battery , other than that it is a job for test equipment.
Yes, no stiffness or resistance. I'll leave the lead-acid battery on a Ctek overnight and try tomorrow to see if the ammeter reads differently.
once had a problem with a datsun240, belt drive to alternator and power steering, bearing seized and belt slipping . battery kept going flat till i found the problem.
I can remember when I was lad.. They used to speed test those on the new M1.
They were doing phenomenal speeds even then.
I can't believe I'm the first one to ask for pictures!
We love pictures on here!
OK, I accept that in this case they won't help with diagnostics, but car----- is always welcome!
On another point...my past experience suggests battery failure, usually caused by alternator fault. Ammeter should show charge for a few minutes after cranking, then settle near to zero...if the physical drivetrain is ok (belt/water pump/alternator) then battery or alternator is the problem.
My pleasure. It's a '65 leafspring street car - no bulges or stripes here, I'm afraid - also only the 4.7, not the 7 litre.
