Discuss Joint box in loft or back to switch in the UK Electrical Forum area at ElectriciansForums.net
Anyone got any pictures of jobs they’ve done using a joint box in loft instead of taking all cables back to your switch position? Eg Spots, Fan, Mirror as our next job has all wall paper on walls so may be a better option just curious to see what it’s like.
Reply to Joint box in loft or back to switch in the UK Electrical Forum area at ElectriciansForums.net
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
Hi all, Customer has an extension and this compromises existing meter position, DNO is extending incomer and putting meter box on a different...
Hi all. Sort of an interesting one. I had a call from a client to say she is getting a shock when using the shower. I told her not to use it and...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
