O
oldtimer
Yep just went ahead and spent £28 for a Fluke case for my Megger as I was getting sick and tired of poking leads back into the megger case Dont get me wrong I like the Megger better than the Fluke but one is a good tester the other a good case
Any thoughts
agree with that,i have a fluke and the case is tough,and well planned out,did have a megger last year,good tester but even with the plastic case they give as you say,leads not catered for.quite annoying
The foam in the bottom of the fluke case is cut to the crescent shape of the fluke but im sure a couple of secs with the trusty stanley should sort that!
To be fair its a great case and you can bung everything in there, leads 1362 adapters, spare batterys, pens, labels.....i keep absolutely everything in mine
I once saw a case on Ebay for Fluke meters etc, was about £60 and it had a load of different pockets for all your hand held test kit, never got one, but it did look the part.
Would save it bouncing about in my tool box under all the snips, hammers etc, so probably money well spent if i get one.
Cheers........Howard
Box now ordered and I will chuck the bag I keep a lot of my test equipment in because there is no room in the megger box plus you can also use the Fluke box as a seat. And fumbling about in a bag lets face it does not make you look the part.
i got my megger in an aluminium case, like a camera case. also fitting in are a small robin IR tester, and a low ohms meter, earth leakage clamp meter. pouch in lid for leads. looks well professional but i wouldn't like to sit my 15 stone on it.
I wouldn't like to sit my 23 stone on any mft case, I reckon at a guess my arse would be straight through it!
