C
ChrisElectrical88
Hey guys.
just looking for some advice to back up what I have told one of the lads. He wired an emergency lighting circuit with a FP coming into the dist board. He took this FP through the board into the key switch mounted on the side of it then a FP back into the board through the bush and coupler. Still following. Probably not! Anyway apart from pointlessly taking the neutral into the switch he connected the lives through the L1 terminal and the neutral through the L2.
i made him disconnect the neutrals as it was a L terminal as they would not be correctly identified. Also he didn't see the reason why the switch didn't need a neutral.
Point anyway way after this ridiculous post is, would you connect a neutral into a L terminal?
