Discuss KWh meter din rail mounted for wylex board in the UK Electrical Forum area at ElectriciansForums.net
T
The Ghost
Hi so any ideas on din mounted MID rated single phase kwh meter? I am required to fit a meter for sockets in a unit. At the moment the sockets are fed from a 32a mcb in a wylex plastic D.B. older type. See photo. All suggestions treated in confidence and will be touted as my own brilliant idea, just kidding you will get full credit and all royalties.
Yeh that is the plan. I was thinking I would need something that would fit in the wylex box. And not sure if any single module would fit.
you've not got a proper din rail for it to grip in a wylex board as the mcb's rely on the busbar to hold them down onto the top lip of the din rail, so a normal din mounted solution isn't going to work :(
OH oh, maybe I'll get a separate din mount box and supply that if necessary. Shouldn't be too much of a probs. just a bit of a fiddle.
Think it may be 12mm for single phase din module from what I have read on the data sheets where available.
Oh yeh and thinking about it I could just buy some din rail and replace the rail in there.
it will fit and clip on the din rail in the Wylex board. I've fitted loads on PV jobs.
On new builds we used an isolator similar to this and a single module KWH meter.
TELERGON SWITCH DIN RAIL 3P 20A DIN RED HANDLE ZBK20SMAHN1A3 TELERGON - https://solar.rubiconsa.com/isolators/ac-isolators/telergon-switch-din-rail-3p-20a-din-red-handle-zbk20smahn1a3.html
I think @suffolkspark has a point, if you look at the piccy you will see it is not a proper din rail it only has the top half for the mcb/module to hang from and the bus bar is holding the bottom part. I think you should be able to see it. But as stated I could just put a proper din rail in there.
I can't see it...maybe I'm getting confused then and the boards wasn't wylex :confused: How does the main switch and RCD's clip on?
Reply to KWh meter din rail mounted for wylex board in the UK Electrical Forum area at ElectriciansForums.net
A few weeks ago I posted this in another thread...: The tripping kept occurring, so I went back and moved a likely candidate circuit to the...
Hi all, I'm looking to shift the wiring of an exceptionally awkwardly placed old fuse board to a shiny new 18th ed compliant board a few metres...
As currently got sod-all to do, I was thinking about the choice of TPN board for a new set up. It only needs 2-3 three phase circuits and around a...
Afternoon - despite a recent 18th edition pass (all but one right!) I'm having a bit of a moment whilst planning some upcoming works at our site...
5K
hi i've bought a hager st303 din rail mounted door bell transformer and a 2 module wylex ESE2 enclosure for it to fit in. i was going to run this...
